Building Innovation Pipelines through Computer-Aided Innovation 4th IFIP WG 5.4 Working Conference, CAI 2011 Strasbourg, France, June 30 – July 1, 2011
Conference papers
The Defect Detection of Fibre Boards Gluing System Based on TRIZ
Abstract : Defect signal is always a problem that interferes with the operation of fibre board gluing control system. Complex problem analysis and solving are an important evolutionary direction of TRIZ. This research creates a defect diagnosis methodology by synthesizing the Theory of Inventive Problem Solving (TRIZ) and a Possibilistic C-Means (PCM) improved Support Vector Data Description (SVDD) method. Applied TRIZ to identify core root causes and confirm contradictions to classify the system defect. A complex problem solving model integrating SVDD and PCM in TRIZ frame is put forward, a case shows the application of this model.
https://hal.inria.fr/hal-01567772
Contributor : Hal Ifip <>
Submitted on : Monday, July 24, 2017 - 2:40:42 PM Last modification on : Monday, July 24, 2017 - 2:43:07 PM
Huiling Yu, Guangsheng Chen, Congchun Xu, Delin Fan. The Defect Detection of Fibre Boards Gluing System Based on TRIZ. 4th Computer-Aided Innovation (CAI), Jun 2011, Strasbourg, France. pp.106-116, ⟨10.1007/978-3-642-22182-8_9⟩. ⟨hal-01567772⟩
