A Lightweight Gait Authentication on Mobile Phone Regardless of Installation Error
Abstract : In this paper, we propose a novel gait authentication mechanism by mining sensor resources on mobile phone. Unlike previous works, both built-in accelerometer and magnetometer are used to handle mobile installation issues, including but not limited to disorientation, and misplacement errors. The authentication performance is improved by executing deep examination at pre-processing steps. A novel and effective segmentation algorithm is also provided to segment signal into separate gait cycles with perfect accuracy. Subsequently, features are then extracted on both time and frequency domains. We aim to construct a lightweight but high reliable model; hence feature subsets selection algorithms are applied to optimize the dimension of the feature vectors as well as the processing time of classification tasks. Afterward, the optimal feature vector is classified using SVM with RBF kernel. Since there is no public dataset in this field to evaluate fairly the effectiveness of our mechanism, a realistic dataset containing the influence of mobile installation errors and footgear is also constructed with the participation of 38 volunteers (28 males, 10 females). We achieved the accuracy approximately 94.93% under identification mode, the FMR, FNMR of 0%, 3.89% and processing time of less than 4 seconds under authentication mode.
Document type :
Conference papers
Complete list of metadatas
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01463861
Contributor : Hal Ifip <>
Submitted on : Thursday, February 9, 2017 - 5:32:37 PM
Last modification on : Thursday, February 9, 2017 - 5:37:18 PM
Long-term archiving on : Wednesday, May 10, 2017 - 2:30:18 PM
File
978-3-642-39218-4_7_Chapter.pd...
Identifiers
Citation
Thang Hoang, Deokjai Choi, Viet Vo, Anh Nguyen, Thuc Nguyen. A Lightweight Gait Authentication on Mobile Phone Regardless of Installation Error. 28th Security and Privacy Protection in Information Processing Systems (SEC), Jul 2013, Auckland, New Zealand. pp.83-101, ⟨10.1007/978-3-642-39218-4_7⟩. ⟨hal-01463861⟩
Share
Metrics
Record views
505
Files downloads
381
