index - IFIP AICT 443: System Modeling and Optimization Access content directly
Full Text Documents
34
Search
Table of Contents
Christian Pötzsche, Clemens Heuberger, Barbara Kaltenbacher, Franz Rendl (Eds.)
Front matter
Stochastic Maximum Principle for Hilbert Space Valued Forward-Backward Doubly SDEs with Poisson Jumps
Abdulrahman Al-Hussein, Boulakhras Gherbal
1-10
Efficient Solvers for Large-Scale Saddle Point Systems Arising in Feedback Stabilization of Multi-field Flow Problems
Peter Benner, Jens Saak, Martin Stoll, Heiko Weichelt
11-20
Stochastic Control of Econometric Models for Slovenia
Dimitri Blueschke, Viktoria Blueschke-Nikolaeva, Reinhard Neck
21-30
The Optimal Control of Cellular Communication Enterprise Development in Competitive Activity
Irina Bolodurina, Tatyana Ogurtsova
31-35
Simulation of Acoustic Wave Propagation in Anisotropic Media Using Dynamic Programming Technique
Nikolai Botkin, Varvara Turova
36-51
Efficient Cardinality/Mean-Variance Portfolios
R. Brito, Luís Vicente
52-73
Two Semi-Lagrangian Fast Methods for Hamilton-Jacobi-Bellman Equations
Simone Cacace, Emiliano Cristiani, Maurizio Falcone
74-84
Dynamic Sampling Schemes for Optimal Noise Learning Under Multiple Nonsmooth Constraints
Luca Calatroni, Juan Los Reyes, Carola-Bibiane Schönlieb
85-95
Exponential Convergence to Equilibrium for Nonlinear Reaction-Diffusion Systems Arising in Reversible Chemistry
Laurent Desvillettes, Klemens Fellner
96-104
A High-Order Semi-Lagrangian/Finite Volume Scheme for Hamilton-Jacobi-Isaacs Equations
Maurizio Falcone, Dante Kalise
105-117
Simultaneous Material and Topology Optimization Based on Topological Derivatives
Jannis Greifenstein, Michael Stingl
118-127
Steady Fluid-Structure Interaction Using Fictitious Domain
Andrei Halanay, Cornel Murea
128-137
Sensitivity of the Solution Set to Second Order Evolution Inclusions
Jiangfeng Han, Stanislaw Migorski
138-147
Impulse Control of Standard Brownian Motion: Long-Term Average Criterion
Kurt Helmes, Richard Stockbridge, Chao Zhu
148-157
Impulse Control of Standard Brownian Motion: Discounted Criterion
158-169
On Target Control Synthesis Under Set-Membership Uncertainties Using Polyhedral Techniques
Elena Kostousova
170-180
Application of the Fenchel Theorem to the Obstacle Problem
Diana Merluşcă
181-188
A Penalization Method for the Elliptic Bilateral Obstacle Problem
Cornel Murea, Dan Tiba
189-198
Binary Level Set Method for Topology Optimization of Variational Inequalities
Andrzej Myśliński
199-209
Nonlinear Delay Evolution Inclusions on Graphs
Mihai Necula, Marius Popescu, Ioan Vrabie
210-219
Graphical Lasso Granger Method with 2-Levels-Thresholding for Recovering Causality Networks
Sergiy Pereverzyev Jr., Kateřina Hlaváčková-Schindler
220-229
Right-Hand Side Dependent Bounds for GMRES Applied to Ill-Posed Problems
Jennifer Pestana
230-236
PDE-Driven Shape Optimization: Numerical Investigation of Different Descent Directions and Projections Using Penalization and Regularization
Peter Philip
237-246
Tomographic Reconstruction of Homogeneous 2D Geometric Models with Unknown Attenuation
Zenith Purisha, Samuli Siltanen
247-256
A Control Delay Differential Equations Model of Evolution of Normal and Leukemic Cell Populations Under Treatment
I. Rădulescu, Doina Cândea, Andrei Halanay
257-266
More Safe Optimal Input Signals for Parameter Estimation of Linear Systems Described by ODE
Ewaryst Rafajłowicz, Wojciech Rafajłowicz
267-277
Exponential Stability of Compactly Coupled Wave Equations with Delay Terms in the Boundary Feedbacks
Salah-Eddine Rebiai, Fatima Sidi Ali
278-284
Model Predictive Control of Temperature and Humidity in Heating, Ventilating and Air Conditioning Systems
Jakob Rehrl, Daniel Schwingshackl, Martin Horn
285-295
Regularization of Linear-Quadratic Control Problems with $$L^1$$ -Control Cost
Christopher Schneider, Walter Alt
296-305
Deployment of Sensors According to Quasi-Random and Well Distributed Sequences for Nonparametric Estimation of Spatial Means of Random Fields
Ewa Skubalska-Rafajłowicz, Ewaryst Rafajłowicz
306-316
On the Diversity Order of UW-OFDM
Heidi Steendam
317-326
Representation and Analysis of Piecewise Linear Functions in Abs-Normal Form
Tom Streubel, Andreas Griewank, Manuel Radons, Jens-Uwe Bernt
327-336
Efficient Smoothers for All-at-once Multigrid Methods for Poisson and Stokes Control Problems
Stefan Takacs
337-347
Continuous-TimeLocal Model Network for the Boost-Pressure Dynamics of a Turbocharger
Christoph Weise, Kai Wulff, Marc-Hinrik Höper, Romain Hurtado
348-358
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
