Convolutive Audio Source Separation Using Robust ICA and Reduced Likelihood Ratio Jump
Abstract : Audio source separation is the task of isolating sound sources that are active simultaneously in a room captured by a set of microphones. Convolutive audio source separation of equal number of sources and microphones has a number of shortcomings including the complexity of frequency-domain ICA, the permutation ambiguity and the problem’s scalabity with increasing number of sensors. In this paper, the authors propose a multiple-microphone audio source separation algorithm based on a previous work of Mitianoudis and Davies [1]. Complex FastICA is substituted by Robust ICA increasing robustness and performance. Permutation ambiguity is solved using the Likelihood Ration Jump solution, which is now modified to decrease computational complexity in the case of multiple microphones.
Document type :
Conference papers
Complete list of metadatas
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01557598
Contributor : Hal Ifip <>
Submitted on : Thursday, July 6, 2017 - 1:55:04 PM
Last modification on : Friday, August 9, 2019 - 4:12:12 PM
Long-term archiving on : Wednesday, January 24, 2018 - 1:28:31 AM
File
430537_1_En_20_Chapter.pdf
Identifiers
Citation
Dimitrios Mallis, Thomas Sgouros, Nikolaos Mitianoudis. Convolutive Audio Source Separation Using Robust ICA and Reduced Likelihood Ratio Jump. 12th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2016, Thessaloniki, Greece. pp.230-241, ⟨10.1007/978-3-319-44944-9_20⟩. ⟨hal-01557598⟩
Share
Metrics
Record views
89
Files downloads
178
