Full Text Documents
49
Search
Table of Contents
System Modeling and Optimization
Lorena Bociu, Jean-Antoine Désidéri, Abderrahmane Habbal
Front Matter
Control Methods for the Optimization of Plasma Scenarios in a Tokamak
Jacques Blum, Cédric Boulbe, Blaise Faugeras, Holger Heumann
1-20
Approximation of the Equations of the Humid Atmosphere with Saturation
Roger Temam, Xiaoyan Wang
21-42
Parameter Estimation in a Size-Structured Population Model with Distributed States-at-Birth
Azmy Ackleh, Xinyu Li, Baoling Ma
43-57
On the Optimal Control of Opinion Dynamics on Evolving Networks
Giacomo Albi, Lorenzo Pareschi, Mattia Zanella
58-67
Coupling MPC and DP Methods for an Efficient Solution of Optimal Control Problems
A. Alla, G. Fabrini, M. Falcone
68-77
Real Options and Threshold Strategies
Vadim Arkin, Alexander Slastnikov
78-88
Electrostatic Approximation of Vector Fields
Giles Auchmuty
89-94
Modelling Pesticide Treatment Effects on Lygus hesperus in Cotton Fields
H. Banks, J. Banks, Neha Murad, J. Rosenheim, K. Tillman
95-106
Extension of p-Laplace Operator for Image Denoising
George Baravdish, Yuanji Cheng, Olof Svensson, Freddie Åström
107-116
Preconditioned ADMM with Nonlinear Operator Constraint
Florian Knoll, Carola-Bibiane Schönlieb, Tuomo Valkonen, Martin Benning
117-126
Regularized Optimal Design Problem for a Viscoelastic Plate Vibrating Against a Rigid Obstacle
Igor Bock
127-136
Optimal Abort Landing in the Presence of Severe Windshears
Nikolai Botkin, Varvara Turova
137-146
Aircraft Runway Acceleration in the Presence of Severe Wind Gusts
147-158
Dynamic Programming Approach for Discrete-Valued Time Discrete Optimal Control Problems with Dwell Time Constraints
Michael Burger, Matthias Gerdts, Simone Göttlich, Michael Herty
159-168
Infimal Convolution Regularisation Functionals of $$\mathrm {BV}$$ and $$\mathrm {L}^{p}$$ Spaces. The Case $$p=\infty $$
Martin Burger, Konstantinos Papafitsoros, Evangelos Papoutsellis, Carola-Bibiane Schönlieb
169-179
Successive Approximation of Nonlinear Confidence Regions (SANCR)
Thomas Carraro, Vladislav Olkhovskiy
180-188
Two-Phase Multi-criteria Server Selection for Lightweight Video Distribution Systems
Octavian Catrina, Eugen Borcoci, Piotr Krawiec
189-199
Hamilton-Jacobi-Bellman Equation for a Time-Optimal Control Problem in the Space of Probability Measures
Giulia Cavagnari, Antonio Marigonda, Giandomenico Orlandi
200-208
Strong Optimal Controls in a Steady-State Problem of Complex Heat Transfer
Alexander Chebotarev, Andrey Kovtanyuk, Nikolai Botkin, Karl-Heinz Hoffmann
209-219
A Non-autonomous Stochastic Discrete Time System with Uniform Disturbances
Ioannis Dassios, Krzysztof Szajowski
220-229
Differentials and Semidifferentials for Metric Spaces of Shapes and Geometries
Michel Delfour
230-239
Necessary Optimality Conditions in a Problem with Integral Equations on a Nonfixed Time Interval Subject to Mixed and State Constraints
Andrei Dmitruk, Nikolai Osmolovskii
240-249
A Criterion for Robust Stability with Respect to Parametric Uncertainties Modeled by Multiplicative White Noise with Unknown Intensity, with Applications to Stability of Neural Networks
Vasile Dragan, Adrian-Mihail Stoica, Toader Morozan
250-260
Optimal Control of Doubly Nonlinear Evolution Equations Governed by Subdifferentials Without Uniqueness of Solutions
M. Farshbaf-Shaker, Noriaki Yamazaki
261-271
Derivation of a Macroscopic LWR Model from a Microscopic follow-the-leader Model by Homogenization
Nicolas Forcadel, Mamdouh Zaydan
272-281
Cahn–Hilliard Approach to Some Degenerate Parabolic Equations with Dynamic Boundary Conditions
Takeshi Fukao
282-291
Uniform Estimation of a Constant Issued from a Fluid-Structure Interaction Problem
Andrei Halanay, Cornel Murea
292-301
A Multivalued Variational Inequality with Unilateral Constraints
Piotr Kalita, Stanislaw Migorski, Mircea Sofonea
302-311
On the Solvability of a Nonlinear Tracking Problem Under Boundary Control for the Elastic Oscillations Described by Fredholm Integro-Differential Equations
Akylbek Kerimbekov, Elmira Abdyldaeva
312-321
Observability of a Ring Shaped Membrane via Fourier Series
Vilmos Komornik, Paola Loreti, Michel Mehrenberger
322-330
A Mixed Approach to Adjoint Computation with Algorithmic Differentiation
Kshitij Kulshreshtha, Sri Narayanan, Tim Albring
331-340
Sparsity Constrained Image Restoration: An Approach Using the Newton Projection Method
Germana Landi
341-350
The Hilbert Uniqueness Method for a Class of Integral Operators
Paola Loreti, Daniela Sforza
351-359
Game Control Problem for Systems of Distributed Equations
Vyacheslav Maksimov
360-369
On the Weak Solvability and the Optimal Control of a Frictional Contact Problem with Normal Compliance
Andaluzia Matei
370-379
Multimaterial Topology Optimization of Variational Inequalities
Andrzej Myśliński
380-389
Implicit Parametrizations and Applications
Mihaela Nicolai, Dan Tiba
390-398
Approximate Riesz Representatives of Shape Gradients
Alberto Paganini, Ralf Hiptmair
399-409
Exploitation of the Value Function in a Bilevel Optimal Control Problem
Konstantin Palagachev, Matthias Gerdts
410-419
Multibody Dynamics with Unilateral Constraints: Computational Modelling of Soft Contact and Dry Friction
Laetitia Paoli
420-429
A Complex Mathematical Model with Competition in Leukemia with Immune Response - An Optimal Control Approach
I. Rădulescu, D. Cândea, A. Halanay
430-441
A Contact Model for Piezoelectric Beams
Á. Rodríguez-Arós, M. Cao-Rial, M. Sofonea
442-451
Optimization of Engineering Processes Including Heating in Time-Dependent Domains
Alfred Schmidt, Eberhard Bänsch, Mischa Jahn, Andreas Luttmann, Carsten Niebuhr, Jost Vehmeyer
452-461
Generalized Solutions of Hamilton – Jacobi Equation to a Molecular Genetic Model
Nina Subbotina, Lyubov Shagalova
462-471
Dynamic Programming to Reconstruction Problems for a Macroeconomic Model
Nina Subbotina, Timofey Tokmantsev, Eugenii Krupennikov
472-481
Stable Sequential Pontryagin Maximum Principle as a Tool for Solving Unstable Optimal Control and Inverse Problems for Distributed Systems
Mikhail Sumin
482-492
Double Convergence of a Family of Discrete Distributed Mixed Elliptic Optimal Control Problems with a Parameter
Domingo Tarzia
493-504
Modeling and Control of Low-Frequency Electromagnetic Fields in Multiply Connected Conductors
Fredi Tröltzsch, Alberto Valli
505-516
Parameter Estimation Algorithms for Kinetic Modeling from Noisy Data
Fabiana Zama, Dario Frascari, Davide Pinelli, A. Bacca
517-527
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
