Coupling MPC and DP Methods for an Efficient Solution of Optimal Control Problems
Abstract : We study the approximation of optimal control problems via the solution of a Hamilton-Jacobi equation in a tube around a reference trajectory which is first obtained solving a Model Predictive Control problem. The coupling between the two methods is introduced to improve the initial local solution and to reduce the computational complexity of the Dynamic Programming algorithm. We present some features of the method and show some results obtained via this technique showing that it can produce an improvement with respect to the two uncoupled methods.
Document type :
Conference papers
Complete list of metadatas
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01626904
Contributor : Hal Ifip <>
Submitted on : Tuesday, October 31, 2017 - 2:40:57 PM
Last modification on : Tuesday, May 14, 2019 - 10:59:20 AM
Long-term archiving on: Thursday, February 1, 2018 - 1:13:02 PM
File
447583_1_En_5_Chapter.pdf
Identifiers
Citation
A. Alla, G. Fabrini, M. Falcone. Coupling MPC and DP Methods for an Efficient Solution of Optimal Control Problems. 27th IFIP Conference on System Modeling and Optimization (CSMO), Jun 2015, Sophia Antipolis, France. pp.68-77, ⟨10.1007/978-3-319-55795-3_5⟩. ⟨hal-01626904⟩
Share
Metrics
Record views
361
Files downloads
473
