Conference papers
Composable Actor Behaviour
Abstract : Code reusability is the cornerstone of object-oriented programming. Reuse mechanisms such as inheritance and trait composition lay at the basis of a whole range of software engineering practices with the goal to improve software quality and reliability. In this paper we investigate code reuse mechanisms for actors, and find that it is currently difficult to specify the behaviour of an actor out of reusable parts. We discuss different kinds of code reuse mechanisms in different kinds of actor model, and we motivate why these mechanisms are currently unsatisfactory. As a possible solution we define a new reuse mechanism based on delegation-based trait composition. In a nutshell, the mechanism allows programmers to compose the behaviour of actors, and every time a compound behaviour is spawned into an actor, it will cause multiple actors to be spawned (one for each independent behaviour). Some messages will be automatically delegated to the actor that implements the desired functionality. We provide an implementation of this model in a prototype Active Object language called Stella, and we formalise a subset of Stella using a small-step operational semantics to unambiguously define the different steps involved in our reuse mechanism.
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-02319570
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, October 18, 2019 - 9:47:54 AM
Last modification on : Tuesday, October 19, 2021 - 11:00:11 AM
Long-term archiving on: : Sunday, January 19, 2020 - 12:51:16 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2022-01-01
Please log in to resquest access to the document
Identifiers
Citation
Sam van den Vonder, Joeri de Koster, Wolfgang de Meuter. Composable Actor Behaviour. 19th IFIP International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2019, Kongens Lyngby, Denmark. pp.57-73, ⟨10.1007/978-3-030-22496-7_4⟩. ⟨hal-02319570⟩
Share
Metrics
Record views
68
