Distributed Applications and Interoperable Systems 13th IFIP WG 6.1 International Conference, DAIS 2013 Held as Part of the 8th International Federated Conference on Distributed Computing Techniques, DisCoTec 2013,Florence, Italy, June 3-5, 2013
Conference papers
Ambient Clouds: Reactive Asynchronous Collections for Mobile Ad Hoc Network Applications
Abstract : In MANET applications, a common pattern is to maintain and query time-varying collections of remote objects. Traditional approaches require programmers to manually track the connectivity state of these remote objects and adding or removing them from local collections on a per-object basis. Queries over these collections have to be manually recomputed whenever the collection or its elements change.The code for maintaining these ad-hoc collections is scattered across the application code and leads to bugs hindering the application development process. In this paper, we propose an object-oriented abstraction called ambient clouds: a collection of objects whose contents are implicitly updated when changes occur. Ambient clouds can be queried and composed using reactive standard query operators. We show how ambient clouds ease the development of a collaborative peer-to-peer drawing application.
https://hal.inria.fr/hal-01489467 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, March 14, 2017 - 2:19:49 PM Last modification on : Tuesday, October 19, 2021 - 11:00:10 AM Long-term archiving on: : Thursday, June 15, 2017 - 2:12:52 PM
Kevin Pinte, Andoni Lombide Carreton, Elisa Gonzalez Boix, Wolfgang Meuter. Ambient Clouds: Reactive Asynchronous Collections for Mobile Ad Hoc Network Applications. 13th International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2013, Florence, Italy. pp.85-98, ⟨10.1007/978-3-642-38541-4_7⟩. ⟨hal-01489467⟩
