Conference papers
Dynamic Strategies for Query Constructing and Rank Merging from Multiple Search Engines
Abstract : Heterogeneous search engines differ in the algorithms they use and the domains they cover, thus there is no single search engine that performs best in every circumstance. In order to obtain optimal search results, it often makes sense to use more than one search engine. However, appropriately merging results from different engines is challenging, i.e. combining results in such a way that they reflect the ranking of results the user would choose. In this paper, we propose an effective way to achieve this for web services search which can be extended to cloud services and be applied to big data. In contrast to “classical” search processed by conventional text-based search engines, a more elaborated search request is needed here. In addition to the result merging, we therefore present a method to create a structured request for this specific task. The evaluation of our proposed solution shows that it is satisfying in terms of both result quality and performance.
Document type :
Conference papers
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01757570
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, April 3, 2018 - 5:20:17 PM
Last modification on : Monday, November 29, 2021 - 3:39:02 PM
File
370579_1_En_10_Chapter.pdf
Identifiers
Citation
Kobkaew Opasjumruskit, Birgitta König-Ries, Jesús Expósito. Dynamic Strategies for Query Constructing and Rank Merging from Multiple Search Engines. 4th European Conference on Service-Oriented and Cloud Computing (ESOCC), Sep 2015, Taormina, Italy. pp.141-155, ⟨10.1007/978-3-319-24072-5_10⟩. ⟨hal-01757570⟩
Share
Metrics
Record views
538
Files downloads
568
