Ultrasonic rheology of visco-elastic materials using shear and longitudinal waves - Modélisation, Propagation et Imagerie Acoustique Accéder directement au contenu
Article Dans Une Revue Applied Physics Letters Année : 2018
We present a technique for determining the rheology of visco-elastic materials in the ultrasonic frequency range based on the measurement of the longitudinal and shear waves reflected and transmitted by a slab of material with a controlled thickness sandwiched between two delay lines. The high sensitivity of this Fabry-P erot resonator-based technique allows one to access characteristic relaxation times associated with visco-elasticity. As a useful application of the technique, we characterize the Olympus SWC-2 shear-wave couplant in the 0.7-5 MHz frequency range.
Lefebvre_2018_112.pdf (765.6 Ko) Télécharger le fichier
hal-01921803 , version 1 (14-11-2018)
Gautier Lefebvre, Régis Wunenburger, Tony Valier-Brasier. Ultrasonic rheology of visco-elastic materials using shear and longitudinal waves. Applied Physics Letters, 2018, 112 (24), ⟨10.1063/1.5029905⟩. ⟨hal-01921803⟩
138 Consultations
260 Téléchargements
