PPM Publications
[hal-03453746] Onset of the Younger Dryas Recorded with 14 C at Annual Resolution in French Subfossil Trees – ERRATUM
(11/30/21)
[halshs-03448026] Archéologie maritime, archéologie navale et dendrochronologie
(11/26/21)
[hal-03310353] First high resolution chronostratigraphy for the early North African Acheulean at Casablanca (Morocco)
(11/24/21)
[hal-03441636] Positive challenges for research in the changing Mediterranean environment
(11/24/21)
[hal-03438372] Larch building in the Southern French Alps since the 10th century : a new dendrochronological reading of long-term human occupation in the mountain
(11/25/21)
[hal-03437876] Contribution à la connaissance des lépidoptères et coléoptères crépusculaires et nocturnes de l'île de Port-Cros (archipel des Îles d'Hyères, Var, France)
(11/24/21)
[hal-03437791] Etat sanitaire des peuplements de pin d’Alep (Pinus halepensis Mill.) dans le massif forestier de Senalba (Djelfa, Algérie)
(11/22/21)
[hal-03437016] A note on the biogeographical origin of the brine shrimp Artemia urmiana Günther, 1899 from Urmia Lake, Iran
(11/21/21)
[hal-03209442] Land Use Changes Threaten Bird Taxonomic and Functional Diversity Across the Mediterranean Basin: A Spatial Analysis to Prioritize Monitoring for Conservation
(12/1/21)
[hal-03416194] Sur quelques Coléoptères saproxyliques remarquables ou nouveaux pour la France métropolitaine
(12/2/21)
