Accurate 3D Lighthouse Localization of a Low-Power Crystal-Free Single-Chip Mote - Inria@SiliconValley Accéder directement au contenu
Article Dans Une Revue Journal of Microelectromechanical Systems Année : 2020
We present a system for centimeter-precision 3 dimensional localization of a 2×3×0.3 mm3, 5 mg, wireless system-on-chip by utilizing a temporally-structured infrared illumination scheme generated by a set of base stations. This 3D localization system builds on previous work by adding a second lighthouse station to enable 3D localization and using the integrated wireless radio, making the localization system fully wireless. We demonstrate 3D tracking with mean absolute errors of 1.54 cm, 1.50 cm,and 5.1 cm for the X, Y, and Z dimensions. This is the first time such a lighthouse localization system has been able to localize amonolithic single-chip wireless system.
kilberg20accurate.pdf (4.65 Mo) Télécharger le fichier
hal-02916806 , version 1 (18-08-2020)
Brian Kilberg, Felipe M R Campos, Filip Maksimovic, Thomas Watteyne, Kristofer S J Pister. Accurate 3D Lighthouse Localization of a Low-Power Crystal-Free Single-Chip Mote. Journal of Microelectromechanical Systems, 2020, 29 (5), ⟨10.1109/JMEMS.2020.3011460⟩. ⟨hal-02916806⟩
181 Consultations
616 Téléchargements
