Nanofibres optiques pour la réalisation de sources de photons corrélés - Thèse de l'Institut d'Optique Graduate School Accéder directement au contenu
Thèse Année : 2019
Optical nanofibers for correlated photon sources
Abderrahim Azzoune
Sources of correlated photon pairs are key components required for quantum telecommunications networks. Implementing these sources directly with optical fibers minimizes the insertion losses. We propose to design such a source from a tapered optical fiber.The tapered fiber has a diameter lower than 500 nm over a length of a few centimeters. The small diameter of the tapered section favors the non-linear effects, while the unstretched sections make it possible to connect this tapered fiber with the fibers of the telecommunication networks with very low losses.In this thesis, we present a design of a new source, fully fibered of correlated photons based on standard telecommunications tapered fibers (SMF28). To produce these pairs of photons we will use the parametric fluorescence due to symmetry breaking at the surface of a silica nanofiber.We have developed an optical microscopy measurement technique to measure all the profile of tapered fibers with nanometer resolution far beyond the diffraction limit.In parallel, we modeled the second-order nonlinear surface susceptibility by taking into account the vector aspect of the propagation of the optical field in a two or three-layered microfiber. In a second step, we define modal phase matchings that are necessary to obtain a strong parametric fluorescence. We size this nanofiber for a good optimization of pairs generation efficiency. The entire process of photon creation will be modeled.
Les sources de paires de photons corrélés sont des composants clés nécessaires aux réseaux de télécommunications quantiques. Réaliser directement ces sources à partir de fibres optiques permet de minimiser les pertes d'insertion. Nous proposons de concevoir une telle source à partir d'une fibre optique étirée. La fibre étirée possède un diamètre pouvant descendre à moins de 500 nm sur une longueur de quelques centimètres. Le faible diamètre de la section étirée favorise les effets non linéaires, tandis que les sections non étirées permettent de connecter avec de très faibles pertes cette fibre étirée avec les fibres des réseaux de télécommunication.Dans cette thèse, nous présentons donc une conception d’une nouvelle source de photons corrélés totalement fibrée à base de fibres standard de télécommunications (SMF28) étirées. Pour produire ces paires de photons nous utiliserons la fluorescence paramétrique due à la brisure de symétrie à la surface de la nanofibre en silice.Nous avons développé une technique de mesure par microscopie optique, qui permet de mesurer tout le profil de la fibre étirée avec une résolution nanométrique bien au-delà de la limite de diffraction.En parallèle, nous avons modélisé la susceptibilité non linéaire de surface de second ordre en prenant en compte l’aspect vectoriel de la propagation du champ optique dans une microfibre à deux ou trois couches. Dans un second temps, nous définissons les accords de phase modaux qui sont nécessaires pour l’obtention d’une forte fluorescence paramétrique. Nous dimensionnons cette nanofibre pour une bonne optimisation de l’efficacité de génération des paires. L'ensemble du processus de création de photons sera modélisé.
AZZOUNE.pdf (5.56 Mo) Télécharger le fichier
tel-02527173 , version 1 (01-04-2020)
tel-02527173 , version 2 (15-05-2020)
tel-02527173 , version 3 (15-07-2020)
  • HAL Id : tel-02527173 , version 3
Abderrahim Azzoune. Nanofibres optiques pour la réalisation de sources de photons corrélés. Optique [physics.optics]. Université Paris Saclay (COmUE), 2019. Français. ⟨NNT : 2019SACLO009⟩. ⟨tel-02527173v3⟩
381 Consultations
162 Téléchargements
