Few-cycles high energy fYb-doped fiber amplifier system
Source laser à fibre dopée Yb de haute énergie délivrant des impulsions de quelques cycles optiques
Femtosecond Yb–doped fiber lasers are commonly used in industry because of their high average power. This permits to increase the speed of fabrication processes. However, in scientific applications, the vast majority of high-intensity physics experiments are nowadays driven using Ti:Sapphire lasers. The key point in these applications is often the pulse duration and Ti:Sapphire lasers typically generate 30 fs pulses whereas Yb-doped fiber lasers generate only 300 fs pulses because of gain narrowing.In this thesis, we have sought to generate few-cycle pulses (< 10fs) from Yb-doped fiber lasers. First, we optimize the laser architecture by using spectral amplitude shaping in order to counterbalance gain narrowing. This allows to generate 130 fs pulse duration.To obtain even shorter pulses we added a nonlinear compression set-up after the laser, based on self-phase modulation. For high energy, the most commonly used nonlinear medium is gas-filled capillaries. This set-up allows us to generate 15 fs pulse duration. Nevertheless the transmission of the set-up is limited to 50 %.A second scheme is studied which overcomes this limitation: the gas-filled Multi-Pass Cell. We experimentally demonstrate for the first time nonlinear compression of a high-energy Yb-doped fiber source in this novel implementation. The use of this architecture permits to reach high transmission but the compression factor at the output of the set-up is limited by the mirror coatings.To produce few-cycles pulse duration, we combine the two aforementionned schemes, allowing the generation of two-cycle (6.8 fs) pulse duration with a high overall transmission. This global architecture will enable a new generation of high-energy compact few-cycle laser sources.
Les lasers femtoseconde à fibre dopée Yb sont aujourd'hui largement utilisés dans le domaine industriel parce que leur puissance moyenne est élevée. Cela permet d'accélérer les processus de fabrication. Cependant, les lasers à cristaux dopés Ti-Sa dominent dans les applications scientifiques parce que la durée d'impulsion est souvent le critère principal. Ces derniers produisent des impulsions d'une durée inférieure à 30 fs alors que les lasers à fibre dopée Yb, limités par la bande de gain du milieu amplificateur, ne génèrent que des durées de 300 fs.Cette thèse a permis de démontrer la génération, en sortie d'amplificateur à fibre dopée ytterbium, d'impulsion à haute énergie de quelques cycles optiques. Pour ce faire, la durée des impulsions est d'abord réduite en sortie d'amplificateur grâce à l'optimisation de l'architecture laser par façonnage spectral avant amplificateur de puissance afin de limiter l'impact du rétrécissement spectral par le gain. Cette technique permet de générer des impulsions de 130 fs.Afin d'obtenir des durées encore plus courte, une seconde technique de réduction de la durée des impulsions est utilisée après le laser utilisant l'auto-modulation de phase. Le milieu non-linéaire le plus courant utilisé pour des lasers de haute énergie est le capillaire rempli de gaz. L'utilisation de ce milieu nous permet de générer des durées d'impulsions de 15 fs mais est limité par son encombrement et sa transmission.Un deuxième schéma de compression non-linéaire est étudié afin de dépasser cette limitation : la Cellule Multi-Passage. L'utilisation de ce type d'architecture permet effectivement d'atteindre des transmission très élevées mais la contrainte sur le traitement des miroirs de la cellule limite le facteur de compression.Pour générer des durée d'impulsions de quelques cycles optiques, nous avons donc proposé de combiner les deux architectures étudiées en utilisant les avantages de chacune, permettant ainsi générer des impulsions de 2 cycles optiques (6.8 fs). Cette architecture globale permet la création de sources d'impulsions de haute énergie et de très courtes durées compactes et efficaces.
Origin : Version validated by the jury (STAR)
