Abnormal Curves in a Zermelo Navigation Problem in the Plane and the Fan Shape of Small Time Balls - Calcul Intensif, Simulation, Optimisation Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this article, based on two cases studies, we discuss the role of abnormal geodesics in planar Zermelo navigation problems. Such curves are limit curves of the accessibility set, in the domain where the current is strong. The problem is set in the frame of geometric time optimal control, where the control is the heading angle of the ship and in this context, abnormal curves are shown to separate time minimal curves from time maximal curves and are both small time minimizing and maximizing. We describe the small time minimal balls. For bigger time, a cusp singularity can occur in the abnormal direction, which corresponds to a conjugate point along the nonsmooth geodesic. It is interpreted in terms of regularity property of the time minimal value function.
2020-BCGW-preprint_V4.pdf (333.42 Ko) Télécharger le fichier
hal-02437507 , version 1 (13-01-2020)
hal-02437507 , version 2 (24-07-2020)
hal-02437507 , version 3 (27-07-2020)
hal-02437507 , version 4 (16-12-2020)
hal-02437507 , version 5 (09-04-2021)
hal-02437507 , version 6 (10-01-2022)
  • HAL Id : hal-02437507 , version 4
Bernard Bonnard, Olivier Cots, Joseph Gergaud, Boris Wembe. Abnormal Curves in a Zermelo Navigation Problem in the Plane and the Fan Shape of Small Time Balls. 2020. ⟨hal-02437507v4⟩
1213 Consultations
513 Téléchargements
