A PAC-Bayes Analysis of Adversarial Robustness - Fiabilité des Systèmes et des Logiciels Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Paul Viallard
Amaury Habrard
Emilie Morvant
We propose the first general PAC-Bayesian generalization bounds for adversarial robustness, that estimate, at test time, how much a model will be invariant to imperceptible perturbations in the input. Instead of deriving a worst-case analysis of the risk of a hypothesis over all the possible perturbations, we leverage the PAC-Bayesian framework to bound the averaged risk on the perturbations for majority votes (over the whole class of hypotheses). Our theoretically founded analysis has the advantage to provide general bounds (i) independent from the type of perturbations (i.e., the adversarial attacks), (ii) that are tight thanks to the PAC-Bayesian framework, (iii) that can be directly minimized during the learning phase to obtain a robust model on different attacks at test time.
arxiv.pdf (302.74 Ko) Télécharger le fichier
hal-03145332 , version 1 (18-02-2021)
hal-03145332 , version 2 (26-10-2021)
  • HAL Id : hal-03145332 , version 1
Guillaume Vidot, Paul Viallard, Amaury Habrard, Emilie Morvant. A PAC-Bayes Analysis of Adversarial Robustness. 2021. ⟨hal-03145332v1⟩
Collections
SMS
332 Consultations
192 Téléchargements
