Conservative parametric optimality and the ridge method for tame min-max problems - Intelligence Artificielle Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We study the ridge method for min-max problems, and investigate its convergence without any convexity, differentiability or qualification assumption. The central issue is to determine whether the "parametric optimality formula" provides a conservative field, a notion of generalized derivative well suited for optimization. The answer to this question is positive in a semi-algebraic, and more generally definable, context. The proof involves a new characterization of definable conservative fields which is of independent interest. As a consequence, the ridge method applied to definable objectives is proved to have a minimizing behavior and to converge to a set of equilibria which satisfy an optimality condition. Definability is key to our proof: we show that for a more general class of nonsmooth functions, conservativity of the parametric optimality formula may fail, resulting in an absurd behavior of the ridge method.
partialMinimization.pdf (483.83 Ko) Télécharger le fichier
hal-03186676 , version 1 (31-03-2021)
hal-03186676 , version 2 (04-02-2022)
hal-03186676 , version 3 (26-12-2022)
hal-03186676 , version 4 (23-06-2023)
Edouard Pauwels. Conservative parametric optimality and the ridge method for tame min-max problems. 2022. ⟨hal-03186676v3⟩
282 Consultations
208 Téléchargements
