Zermelo Navigation Problems on Surfaces of Revolution and Geometric Optimal Control - IRIT - Toulouse INP Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2023
In this article, the historical study from Carathéodory-Zermelo about computing the quickest nautical path is generalized to Zermelo navigation problems on surfaces of revolution, in the frame of geometric optimal control. Using the Maximum Principle, we present two methods dedicated to analyzing the geodesic flow and to compute the conjugate and cut loci. We apply these calculations to investigate case studies related to applications in hydrodynamics, space mechanics and geometry.
cocv-2022-no-template.pdf (1.79 Mo) Télécharger le fichier
hal-03209491 , version 1 (27-04-2021)
hal-03209491 , version 2 (07-05-2021)
hal-03209491 , version 3 (31-03-2022)
hal-03209491 , version 4 (07-03-2023)
hal-03209491 , version 5 (04-07-2023)
Bernard Bonnard, Olivier Cots, Boris Wembe. Zermelo Navigation Problems on Surfaces of Revolution and Geometric Optimal Control. ESAIM: Control, Optimisation and Calculus of Variations, 2023, 29 (60), pp.34. ⟨10.1051/cocv/2023052⟩. ⟨hal-03209491v5⟩
940 Consultations
380 Téléchargements
