Indoor UWB localisation: LocURa4IoT testbed and dataset presentation - Réseaux, Mobiles, Embarqués, Sans fil, Satellites Accéder directement au contenu
This paper introduces the Localisation and UWB-Based Ranging testbed for the Internet of Things (LocURa4IoT). This platform has been built to aid in the design and performance evaluation of proposals addressing the issue of indoor localization. The paper presents the experiment submission process and describes the demonstrations of the testbed capabilities and characteristics. The same scenario has been executed beforehand and the resulting dataset is made available online to the community.
LCN_demo_2022.pdf (542.34 Ko) Télécharger le fichier
hal-03702352 , version 1 (23-06-2022)
  • HAL Id : hal-03702352 , version 1
Quentin Vey, Réjane Dalcé, Adrien van den Bossche, Thierry Val. Indoor UWB localisation: LocURa4IoT testbed and dataset presentation. 47th IEEE Conference on Local Computer Networks (LCN 2022), IEEE, Sep 2022, Edmonton, Canada. ⟨hal-03702352⟩
214 Consultations
172 Téléchargements
