Finding a Suitable Class Distribution for Building Histological Images Data Sets Used in Deep Model Training - the Case of Cancer Detection - Systèmes d’Informations Généralisées Accéder directement au contenu
Article Dans Une Revue Journal of Digital Imaging Année : 2022
The class distribution of a training data set is an important factor which influences the performance of a deep learning-based system. Understanding the optimal class distribution is therefore crucial when building a new training set which may be costly to annotate. This is the case for histological images used in cancer diagnosis where image annotation requires domain experts. In this paper we tackle the problem of finding the optimal class distribution of a training set to be able to train an optimal model that detects cancer in histological images. We formulate several hypotheses which are then tested in scores of experiments with hundreds of trials. The experiments have been designed to account for both segmentation and clas
Finding a Suitable Class Distribution.pdf (8.93 Mo) Télécharger le fichier
hal-03604324 , version 1 (10-03-2022)
  • HAL Id : hal-03604324 , version 1
Ismat Ara Reshma, Camille Franchet, Margot Gaspard, Radu Tudor Ionescu, Josiane Mothe, et al.. Finding a Suitable Class Distribution for Building Histological Images Data Sets Used in Deep Model Training - the Case of Cancer Detection. Journal of Digital Imaging, inPress, pp.1-25. ⟨hal-03604324⟩
171 Consultations
152 Téléchargements
