Skeleton Based Cage Generation Guided by Harmonic Fields - Structural Models and Tools in Computer Graphics Accéder directement au contenu
Article Dans Une Revue Computers and Graphics Année : 2019
We propose a novel user-assisted cage generation tool. We start from a digital character and its skeleton, and create a coarse control cage for its animation. Our method requires minimal interaction to select bending points on the skeleton, and computes the corresponding cage automatically. The key contribution is a volumetric field defined in the interior of the character and embedding the skeleton. The integral lines of such field are used to propagate cutting surfaces from the interior of the character to its skin, and allow us to robustly trace non-planar cross sections that adapt to the local shape of the character. Our method overcomes previous approaches that rely on the popular (but tedious and limiting) cutting planes. We validated our software on a variety of digital characters. Our final cages are coarse yet entirely compliant with the structure induced by the underlying skeleton, enriched with the semantics provided by the bending points selected by the user. Automatic placement of bending nodes for a fully automatic caging pipeline is also supported.
final.pdf (46.94 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
Format : Figure, Image
hal-02113902 , version 1 (06-06-2019)
Sara Casti, Marco Livesu, Nicolas Mellado, Nadine Abu Rumman, Riccardo Scateni, et al.. Skeleton Based Cage Generation Guided by Harmonic Fields. Computers and Graphics, 2019, 81, pp.140-151. ⟨10.1016/j.cag.2019.04.004⟩. ⟨hal-02113902⟩
341 Consultations
59 Téléchargements
