SHREC'19 track: Feature Curve Extraction on Triangle Meshes - Structural Models and Tools in Computer Graphics Accéder directement au contenu
E Moscoso Thompson
  • Fonction : Auteur
G Arvanitis
  • Fonction : Auteur
K Moustakas
  • Fonction : Auteur
N Hoang-Xuan
  • Fonction : Auteur
E R Nguyen
  • Fonction : Auteur
M Tran
  • Fonction : Auteur
C Romanengo
  • Fonction : Auteur
S Biasotti
  • Fonction : Auteur
B Falcidieno
  • Fonction : Auteur
This paper presents the results of the SHREC'19 track: Feature curve extraction on triangle meshes. Given a model, the challenge consists in automatically extracting a subset of the mesh vertices that jointly represent a feature curve. As an optional task, participants were requested to send also a similarity evaluation among the feature curves extracted. The various approaches presented by the participants are discussed, together with their results. The proposed methods highlight different points of view of the problem of feature curve extraction. It is interesting to see that it is possible to deal with this problem with good results, despite the different approaches.
sh19_FeatCurve_preprint.pdf (15.47 Mo) Télécharger le fichier
hal-02126739 , version 1 (19-11-2019)
  • HAL Id : hal-02126739 , version 1
E Moscoso Thompson, G Arvanitis, K Moustakas, N Hoang-Xuan, E R Nguyen, et al.. SHREC'19 track: Feature Curve Extraction on Triangle Meshes. 12th EG Workshop 3D Object Retrieval 2019, May 2019, Gênes, Italy. pp.1 - 8. ⟨hal-02126739⟩
312 Consultations
43 Téléchargements
