Multi-Fidelity Transfer Learning for accurate data-based PDE approximation - IRT SystemX Accéder directement au contenu
Wenzhuo Liu
  • Fonction : Auteur
  • PersonId : 1079812
Mouadh Yagoubi
  • Fonction : Auteur
  • PersonId : 1054942
David Danan
Marc Schoenauer
Data-driven approaches to accelerate computation time on PDE-based physical problems have recently received growing interest. Deep Learning algorithms are applied to learn from samples of accurate approximations of the PDEs solutions computed by numerical solvers. However, generating a large-scale dataset with accurate solutions using these classical solvers remains challenging due to their high computational cost. In this work, we propose a multi-fidelity transfer learning approach that combines a large amount of low-cost data from poor approximations with a small but accurately computed dataset. Experiments on two physical problems (airfoil flow and wheel contact) show that by transferring prior-knowledge learned from the inaccurate dataset, our approach can predict well PDEs solutions, even when only a few samples of highly accurate solutions are available.
MultiFidelityTransfer.pdf (319.7 Ko) Télécharger le fichier
hal-03878200 , version 1 (30-11-2022)
hal-03878200 , version 2 (08-12-2022)
  • HAL Id : hal-03878200 , version 1
Wenzhuo Liu, Mouadh Yagoubi, David Danan, Marc Schoenauer. Multi-Fidelity Transfer Learning for accurate data-based PDE approximation. NeurIPS 2022 - Machine Learning and the Physical Sciences Workshop at the 36th conference on Neural Information Processing Systems (NeurIPS), Nov 2022, New Orleans, United States. ⟨hal-03878200v1⟩
190 Consultations
80 Téléchargements
