Fairness seen as Global Sensitivity Analysis - IRT Saint Exupéry - Institut de Recherche Technologique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Ensuring that a predictor is not biased against a sensible feature is the key of Fairness learning. Conversely, Global Sensitivity Analysis is used in numerous contexts to monitor the influence of any feature on an output variable. We reconcile these two domains by showing how Fairness can be seen as a special framework of Global Sensitivity Analysis and how various usual indicators are common between these two fields. We also present new Global Sensitivity Analysis indices, as well as rates of convergence, that are useful as fairness proxies.
main.pdf (610.46 Ko) Télécharger le fichier
hal-03160697 , version 1 (05-03-2021)
hal-03160697 , version 2 (20-09-2021)
Clément Bénesse, Fabrice Gamboa, Jean-Michel Loubes, Thibaut Boissin. Fairness seen as Global Sensitivity Analysis. 2021. ⟨hal-03160697v2⟩
112 Consultations
232 Téléchargements
