On the Design of a Reward-Based Incentive Mechanism for Delay Tolerant Networks - Équipe Services et Architectures pour Réseaux Avancés Accéder directement au contenu
Rapport Année : 2014
A central problem in Delay Tolerant Networks (DTNs) is to persuade mobile nodes to participate in relaying messages. Indeed, the delivery of a message incurs a certain number of costs for a relay. We consider a two- hop DTN in which a source node, wanting to get its message across to the destination as fast as possible, promises each relay it meets a reward. This reward is the minimum amount that offsets the expected delivery cost, as estimated by the relay from the information given by the source (number of existing copies of the message, age of these copies). A reward is given only to the relay that is the first one to deliver the message to the destination. We show that under fairly weak assumptions the expected reward the source pays remains the same irrespective of the information it conveys, provided that the type of information does not vary dynamically over time. On the other hand, the source can gain by adapting the information it conveys to a meeting relay. For the particular cases of two relays or exponentially distributed inter-contact times, we give some structural results of the optimal adaptive policy.
dtn_incentive_report.pdf (315.59 Ko) Télécharger le fichier
hal-01061348 , version 1 (05-09-2014)
hal-01061348 , version 2 (31-03-2015)
  • HAL Id : hal-01061348 , version 1
Tatiana Seregina, Olivier Brun, Rachid Elazouzi, Balakrishna Prabhu. On the Design of a Reward-Based Incentive Mechanism for Delay Tolerant Networks. 2014. ⟨hal-01061348v1⟩
550 Consultations
629 Téléchargements
