Impact of measurement parameters on antenna radiation pattern reconstruction using phaseless iterative technique
This study focuses on the impact of planar nearfield measurement parameters, such as plane size, sampling step and the distance between the Antenna Under Test (AUT) and the measurement plane. The main objective of this work is to determine the optimal near-field measurement parameters that achieve an assessment of far-field (FF) radiation pattern accuracy versus measurement duration.
Mots clés
Nearfield measurements
Antenna characterization
Iterative Fourier Technique
Phaseless techniques
Radiation pattern reconstruction Introduction (Heading 1)
Nearfield measurements Antenna characterization Iterative Fourier Technique Phaseless techniques Radiation pattern reconstruction Introduction (Heading 1)
Sciences de l'ingénieur [physics]
