Joint channel estimation and data detection for high rate OTFS systems - Equipe Models and AlgoriThms for pRocessIng and eXtracting information Accéder directement au contenu
Article Dans Une Revue International Journal of Communication Systems Année : 2023
This paper proposes a new pilot pattern in the Delay-Doppler (DD) domain for the Orthogonal Time Frequency Space (OTFS) system. In contrast to the embeddedpilot schemes, guard intervals are not used so as increase the spectral efficiency. Also, compared to the superimposed design where data symbols and pilots are arranged on the entire DD grid, in the proposed rearrangement, the number of pilots used is only spread over a sub-grid of the DD grid. Hence, the interference of pilots with data symbols is reduced. Afterwards, an algorithm for channel estimation (CE) and symbol detection in the DD domain benefiting from the sparsity of the DD channel is designed. The sparse CE step is formulated as a specific marginalization of the maximum a posteriori (MAP) criterion by providing a Bayesian approach via the MF approximation that involves the VB-EM algorithm. Detection of data symbols is done using a low complexity MP algorithm. We also propose an interference cancellation (IC) scheme to mitigate contamination of data by pilots that is run after each CE step. To achieve a high CE accuracy, based on the mean mutual incoherence property (MIP), a pilot optimization problem for OTFS is formulated, and develop a Simulated Annealing-based algorithm to solve it. Finally, simulation results show that the proposed scheme achieves a good compromise between spectral efficiency, complexity, and performance in terms of Bit Error Rate (BER) and Normalized Mean Square Error (NMSE) when compared to literature benchmarks.
IJCS2023.pdf (1.04 Mo) Télécharger le fichier
hal-04155866 , version 1 (07-07-2023)
Rabah Ouchikh, Thierry Chonavel, Abdeldjalil Aissa El Bey, Mustapha Djeddou. Joint channel estimation and data detection for high rate OTFS systems. International Journal of Communication Systems, 2023, 36 (16), pp.e5579. ⟨10.1002/dac.5579⟩. ⟨hal-04155866⟩
35 Consultations
14 Téléchargements
