Joint channel estimation and symbol detection for OTFS system using a two-stage algorithm - Equipe Models and AlgoriThms for pRocessIng and eXtracting information Accéder directement au contenu
In this paper, we address the challenging problem of high pilot overhead and peak-to-average power ratio (PAPR) in channel estimation in high-mobility scenarios for 5G and beyond. To improve the channel estimation accuracy and enhance the reliability of data detection, we propose a two-stage algorithm for channel estimation and symbol detection in OTFS systems. In the first stage, a coarse estimate of the channel is obtained, followed by interference cancellation. Then, data symbols are detected using a message-passing (MP) algorithm. In the second stage, detected data and pilot symbols are jointly used to accurately estimate the channel. Simulations show that our proposed scheme, namely contiguous embedded pilots (CEP), achieves a good trade-off between complexity and performance in terms of normalized mean square error (NMSE), bit error rate (BER), spectral efficiency, and PAPR when compared to embedded pilot (EP) and superimposed pilot (SP) designs.
20230917085545_362020_1113.pdf (368.54 Ko) Télécharger le fichier
hal-04217810 , version 1 (26-09-2023)
  • HAL Id : hal-04217810 , version 1
Rabah Ouchikh, Abdeldjalil Aissa El Bey, Thierry Chonavel, Mustapha Djeddou. Joint channel estimation and symbol detection for OTFS system using a two-stage algorithm. 57th Asilomar Conference on Signals, Systems, and Computers, Oct 2023, Pacific Grove, California, United States. ⟨hal-04217810⟩
41 Consultations
18 Téléchargements
