Connected perimeter of planar sets - Laboratoire d'excellence en Mathématiques et informatique fondamentale de Lyon Accéder directement au contenu
Article Dans Une Revue Advances in Calculus of Variations Année : 2020
Matteo Novaga
  • Fonction : Auteur
  • PersonId : 1049340
Marco Pozzetta
  • Fonction : Auteur
  • PersonId : 1049341
We introduce a notion of connected perimeter for planar sets defined as the lower semi-continuous envelope of perimeters of approximating sets which are measure-theoretically connected. A companion notion of simply connected perimeter is also studied. We prove a representation formula which links the connected perimeter, the classical perimeter, and the length of suitable Steiner trees. We also discuss the application of this notion to the existence of solutions to a nonlocal minimization problem.
ConnPerim-revisedV7-final.pdf (383.29 Ko) Télécharger le fichier
hal-02162832 , version 1 (22-06-2019)
hal-02162832 , version 2 (08-04-2020)
hal-02162832 , version 3 (14-05-2020)
François Dayrens, Simon Masnou, Matteo Novaga, Marco Pozzetta. Connected perimeter of planar sets. Advances in Calculus of Variations, inPress. ⟨hal-02162832v2⟩
91 Consultations
75 Téléchargements
