Non axiomatisability of positive relation algebras with constants, via graph homomorphisms - Laboratoire d'excellence en Mathématiques et informatique fondamentale de Lyon Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We study the equational theories of composition and intersection on binary relations, with or without their associated neutral elements (identity and full relation). Without these constants, the equational theory coincides with that of semilattice-ordered semigroups. We show that the equational theory is no longer finitely based when adding one or the other constant, refuting a conjecture from the literature. Our proofs exploit a characterisation in terms of graphs and homomorphisms, which we show how to adapt in order to capture standard equational theories over the considered signatures.
topone.pdf (652.14 Ko) Télécharger le fichier
hal-02870687 , version 1 (16-06-2020)
hal-02870687 , version 2 (23-07-2020)
  • HAL Id : hal-02870687 , version 1
Amina Doumane, Damien Pous. Non axiomatisability of positive relation algebras with constants, via graph homomorphisms. 2020. ⟨hal-02870687v1⟩
120 Consultations
606 Téléchargements
