Type Isomorphisms for Multiplicative-Additive Linear Logic - Laboratoire d'excellence en Mathématiques et informatique fondamentale de Lyon Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
We characterize type isomorphisms in the multiplicative-additive fragment of linear logic (MALL), and thus in *-autonomous categories with finite products, extending a result for the multiplicative fragment by Balat and Di Cosmo. This yields a much richer equational theory involving distributivity and cancellation laws. The unit-free case is obtained by relying on the proof-net syntax introduced by Hughes and Van Glabbeek. We use the sequent calculus to extend our results to full MALL, including all units, thanks to a study of cut-elimination and rule commutations.
MALL_isos_FSCD_2023.pdf (837.15 Ko) Télécharger le fichier
hal-04460547 , version 1 (15-02-2024)
  • HAL Id : hal-04460547 , version 1
Rémi Di Guardia, Olivier Laurent. Type Isomorphisms for Multiplicative-Additive Linear Logic. 2024. ⟨hal-04460547⟩
14 Consultations
4 Téléchargements
