Throughput prediction in wireless networks using statistical learning - LAWDN 2010 - Latin-American Workshop on Dynamic Networks Access content directly
Conference Papers Year : 2010
The focus of this work is on the estimation of throughput in wireless networks, more specificaly on IEEE 802.11. Our proposal is based on active measurements and statistical learning tools. We present a methodology where the system is trained during short periods with application flows and probe packets bursts. We learn the relation between throughput obtained by the application and the state of the network, which is inferred from the interarrival times of the probe packets bursts. As a result we obtain a continuous non intrusive methodology that allows to determine the maximum throughput of a wireless connection only knowing some characteristics of the network. We use Support Vector Machines (SVM) for regression and we show results obtained by simulations.
lawdn2010_submission_2.pdf (117.93 Ko) Télécharger le fichier
Dates and versions
inria-00531743 , version 1 (03-11-2010)
Identifiers
  • HAL Id : inria-00531743 , version 1
Cite
Claudina Rattaro, Pablo Belzarena. Throughput prediction in wireless networks using statistical learning. LAWDN - Latin-American Workshop on Dynamic Networks, INTECIN - Facultad de Ingeniería (U.B.A.) - I.T.B.A., Nov 2010, Buenos Aires, Argentina. 4 p. ⟨inria-00531743⟩
Collections
LAWDN-2010
163 View
345 Download
Share
