Étude et valorisation de composés naturels ou d’analogues de synthèse contrôlant l’adhésion de salissures marines - LBCM-UBS Accéder directement au contenu
Thèse Année : 2017
Study of natural or derivatives compounds which have an impact on biofouling
Biofouling induces important economic and ecological problems. This phenomenon includes microorganisms (bacteria, microalgae…) giving the microfouling which allows the macrofouling development with algae, invertebrates and sponges. These organisms colonize every immersed surface as boat hull. The colonization induces reduced speed of ships and fuel overconsumption. In the past, the utilization of AF coatings with heavy metals or pesticides caused environmental problems. The purpose of the study is to find an alternative to AF compounds (copper) respecting the marine medium. The marine environment is an inspiration; a biomimetic approach could be an interesting strategy to inhibit biofouling. In a first part, a screening of one hundred compounds is realized against marine and terrestrial bacteria. Eight molecules from two families (batatasins and hemibastadins) are studied to understand the way of action. Among selected compounds, Dibromohemibastadin-1 (DBHB) from hemibastadin family shows promising AF activities. This molecule is able to inhibit the biofilm formation with an IC50 of 6,44 µg/mL against the bacterium Pseudomonas aeruginosa PAO1 and 12,8 µg/mL for the marine bacterium Paracoccus sp. 4M6. To identify the way of action of DBHB, the impact on the bacterial communication named quorum sensing is investigated. The molecule shows an anti-quorum sensing property. In a second part, another group participating at microfouling is studied: microalgae. In order to evaluate the impact of hemibastadin family in particular DBHB, microalgae adhesion and biofilm formation are characterized. DBHB induces inhibition only on the adhesion and the biofilm formation of the diatom Cylindrotheca closterium. The last part presents the formulation of coatings containing six compounds from the batatasin and hemibastadin families. These coatings have been immersed in a harbor to evaluate the impact on natural microfouling. Furthermore, a new method for the evaluation of AF coatings is developed in controlled conditions, in a photobioreactor. This method allows the evaluation of coatings on the formation of a mixed biofilm (bacteria and microalgae). This method has been established to avoid environmental constraints by immersion in natural condition. This study allows the characterization of the AF property of DBHB. This compound provides promising research path to limit biofouling. Moreover, the development of a test allowing adhesion and microalgae biofilm formation in dynamic condition improves the characterization of compounds activities.
Le développement de salissures marines (ou biofouling) est à l’origine de nombreux problèmes économiques et écologiques. Ces salissures marines sont constituées de microorganismes (bactéries, microalgues…) formant le microfouling sur lequel va se développer le macrofouling constitué de macroorganismes tels que les algues, coquillages et éponges. La formation de ces salissures va induire un ralentissement des navires provoquant une surconsommation de carburant. De plus, l’utilisation de revêtements antisalissures ou peintures antifouling à base de métaux lourds et de biocides dans le passé a conduit à des problèmes environnementaux. L’objectif de la thèse est de rechercher une alternative aux composés actuellement utilisés (cuivre) en respectant le milieu marin. L’environnement est une source d’inspiration, une approche biomimétique pourrait être une stratégie de lutte efficace contre le biofouling. Dans une première partie, un criblage d’une centaine de composés est réalisé contre des souches bactériennes. Huit composés issus des deux familles : les batatasins et les hemibastadins sont étudiées en vue de comprendre leurs modes d’action. Parmi les composés sélectionnés, la famille des hemibastadins comprenant le DiBromoHemiBastadin-1 (DBHB) a montré des propriétés antifouling prometteuses. En effet, cette molécule est capable d’inhiber 50 % la formation du biofilm avec une IC50= 6,44 µg/mL pour la bactérie Pseudomonas aeruginosa PAO1 et une IC50 = 12,8 µg/mL pour la bactérie marine Paracoccus sp. 4M6. Afin de comprendre le mode d’action de cette molécule, son impact sur la communication bactérienne, le quorum sensing est étudié et le composé DBHB est capable de l’inhiber. Dans une seconde partie, un autre groupe d’organismes participant au microfouling est étudié : les microalgues. Afin d’évaluer l’impact de composés de la famille des hemibastadins et notamment du DBHB, l’adhésion et la formation de biofilm de microalgues sont étudiées. Le DBHB montre des inhibitions de l’adhésion et de la formation du biofilm uniquement envers la diatomée Cylindrotheca closterium. Une dernière partie, s’est intéressée à l’évaluation de revêtements contenant six composés de la famille des batatasins et des hemibastadins sur le microfouling naturel. Une méthode d’immersion de revêtements en conditions contrôlées (photobioréacteur) est mise au point afin de pallier aux contraintes environnementales. L’ensemble de cette étude a permis de mettre en évidence les propriétés antifouling du DBHB et de caractériser son mode d’action. Ce composé offre d’intéressantes voies d’étude dans la lutte contre le biofouling. De plus, l’approfondissement des connaissances sur les procédés d’adhésion et de formation de biofilm de microalgues permet de définir de nouvelles stratégies de lutte.
2017theseLe_NorcyT.pdf (13.1 Mo) Télécharger le fichier
tel-01769717 , version 1 (18-04-2018)
  • HAL Id : tel-01769717 , version 1
Tiffany Le Norcy. Étude et valorisation de composés naturels ou d’analogues de synthèse contrôlant l’adhésion de salissures marines. Bactériologie. Université de Bretagne Sud, 2017. Français. ⟨NNT : 2017LORIS453⟩. ⟨tel-01769717⟩
691 Consultations
365 Téléchargements
