Characterization of marine diatom-infecting virus promoters in the model diatom Phaeodactylum tricornutum - Diatom Genomics Accéder directement au contenu
Article Dans Une Revue Scientific Reports Année : 2015
Viruses are considered key players in phytoplankton population control in oceans. However, mechanisms that control viral gene expression in prominent microalgae such as diatoms remain largely unknown. In this study, potential promoter regions isolated from several marine diatom-infecting viruses (DIVs) were linked to the egfp reporter gene and transformed into the Pennales diatom Phaeodactylum tricornutum. We analysed their activity in cells grown under different conditions. Compared to diatom endogenous promoters, novel DIV promoter (ClP1) mediated a significantly higher degree of reporter transcription and translation. Stable expression levels were observed in transformants grown under both light and dark conditions, and high levels of expression were reported in cells in the stationary phase compared to the exponential phase of growth. Conserved motifs in the sequence of DIV promoters were also found. These results allow the identification of novel regulatory regions that drive DIV gene expression and further examinations of the mechanisms that control virus-mediated bloom control in diatoms. Moreover, the identified ClP1 promoter can serve as a novel tool for metabolic engineering of diatoms. This is the first report describing a promoter of DIVs that may be of use in basic and applied diatom research.
srep18708.pdf (881.91 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01257861 , version 1 (18-01-2016)
Paternité
Takashi Kadono, Arisa Miyagawa-Yamaguchi, Nozomu Kira, Yuji Tomaru, Takuma Okami, et al.. Characterization of marine diatom-infecting virus promoters in the model diatom Phaeodactylum tricornutum. Scientific Reports, 2015, 5, pp.18708. ⟨10.1038/srep18708⟩. ⟨hal-01257861⟩
208 Consultations
145 Téléchargements
