Spectral modelling approach for crowd-rhythmic activities performed on steel-concrete composite floors - Laboratoire de Génie Civil et Génie Mécanique Accéder directement au contenu
Article Dans Une Revue Engineering Structures Année : 2024
During the last decades, building floors have become sensitive to vibrations caused by human activities, especially when a group of individuals perform rhythmic activities in a coordinated manner. Resulting effects on floor occupants can range from a mere perception, can pass through discomfort and can even go so far to cause panic. The present paper proposes a spectral modelling approach for crowd-rhythmic activities applied on floor structures. The proposed model comprises a frequency domain model for a single person, combined with coordination factors to account for the lack of synchronization between individuals. The identification of this model was based on vibration experiments carried out on a floor specimen specifically designed for that purpose. Two particular types of rhythmic activity were investigated: jumping and skipping, and performed by up to 16 individuals, where realistic coordination stimulus was adopted. Using least-squares identification procedures, the single person load parameters were determined and predicted load models are in good agreement with their measured counterparts. Resulting parameters are dependent on the motion style of each investigated activity. Coordination factors are also derived from crowd forces and present a hyperbolic decrease by crowd size for jumping activities against an exponential decrease for skipping activities. Based on a closed-form expression using the established crowd model, a design-oriented method is proposed for a simplified evaluation of floor response due to crowd-rhythmic activities and verified against floor response measurements. Slight differences were found between measured and numerical responses due to the variabilities either encountered during experiments or resulting from the load identification process.
El Asri et al - 2024 - Spectral modelling approach for crowd-rhythmic activities _Manuscript_post_author.pdf (1.33 Mo) Télécharger le fichier
hal-04361969 , version 1 (01-03-2024)
Paternité - Pas d'utilisation commerciale
Youssef El Asri, Maël Couchaux, Mohammed Hjiaj, Mladen Lukić. Spectral modelling approach for crowd-rhythmic activities performed on steel-concrete composite floors. Engineering Structures, 2024, 299, pp.117066. ⟨10.1016/j.engstruct.2023.117066⟩. ⟨hal-04361969⟩
33 Consultations
0 Téléchargements
