Lateral-torsional buckling of uniform and tapered welded I-section beams - Laboratoire de Génie Civil et Génie Mécanique Accéder directement au contenu
Article Dans Une Revue Engineering Structures Année : 2024
The current Eurocode 3 rules for buckling of welded I-section members are based on the assumption of hot-rolled flanges. However, flame-cut flanges are widely used in practice and induce significantly different residual stress distributions, affecting the lateral-torsional buckling resistance. Experimental tests and finite element analyses considering residual stress distributions clearly highlighted the beneficial effect of flame-cut flanges compared with hot-rolled flanges on the lateral-torsional buckling resistance of welded I-beams. To complete these preliminary results, a large number of non-linear finite element analyses are performed considering welded beams made of hot-rolled or flame-cut flanges. The beams are composed of steel grades S275 and S355. Numerical results confirm the influence of the flange fabrication process on the buckling behaviour. Eurocode 3 rules are found to be overly conservative for welded beams made of flame-cut flanges. Consequently, proposals are made that are more suitable for estimates of the lateral-torsional buckling resistance of welded beams made of flame-cut flanges. The code rules are also very conservative for welded beams made of hot-rolled flanges with a medium-to-high slenderness. A design method is thus proposed to improve the prediction accuracy of the lateral-torsional buckling resistance of slender welded beams made of hot-rolled flanges. The novel design method from prEurocode 3 provides acceptable values of the buckling resistance for welded beams made of flame-cut flanges but is restricted to uniform doubly symmetric beams. An extension of its scope to mono-symmetric uniform beams as well as tapered beams is thus suggested. An enhanced imperfection factor is proposed, adapted to welded beams made of flame-cut flanges.
Fichier sous embargo
0 2 15
Année Mois Jours
Avant la publication
mardi 23 juillet 2024
Connectez-vous pour demander l'accès au fichier
hal-04485661 , version 1 (25-04-2024)
Paternité - Pas d'utilisation commerciale
Maxime Lebastard, Maël Couchaux, Alain Bureau, Mohammed Hjiaj. Lateral-torsional buckling of uniform and tapered welded I-section beams. Engineering Structures, 2024, 303, pp.117301. ⟨10.1016/j.engstruct.2023.117301⟩. ⟨hal-04485661⟩
12 Consultations
0 Téléchargements
