Theory and Practice of Image B-Spline Interpolation - Algorithms, architectures, image analysis and computer graphics Accéder directement au contenu
Article Dans Une Revue Image Processing On Line Année : 2018
We explain how the B-spline interpolation of signals and, in particular, of images can be efficiently performed by linear filtering. Based on the seminal two-step method proposed by Unser et al. in 1991, we propose two slightly different prefiltering algorithms whose precisions are proven to be controlled thanks to a rigorous boundary handling. This paper contains all the information, theoretical and practical, required to perform efficiently B-spline interpolation for any order and any boundary extension. We describe precisely how to evaluate the kernel and to compute the B-spline interpolator parameters. We show experimentally that increasing the order improves the interpolation quality. As a fundamental application we also provide an implementation of homographic transformation of images using B-spline interpolation.
article.pdf (2.26 Mo) Télécharger le fichier
hal-01846912 , version 1 (23-07-2018)
Thibaud Briand, Pascal Monasse. Theory and Practice of Image B-Spline Interpolation. Image Processing On Line, 2018, 8, pp.99-141. ⟨10.5201/ipol.2018.221⟩. ⟨hal-01846912⟩
193 Consultations
12200 Téléchargements
