Reliable Self-Deployment of Cloud Applications - CONVECS Accéder directement au contenu
Cloud applications consist of a set of interconnected software elements distributed over several virtual machines, themselves hosted on remote physical servers. Most existing solutions for deploying such applications require human intervention to configure parts of the system, do not respect functional dependencies among elements that must be respected when starting them, and do not handle virtual machine failures that can occur when deploying an application. This paper presents a self-deployment protocol that was designed to automatically configure a set of software elements to be deployed on different virtual machines. This protocol works in a decentralized way, i.e., there is no need for a centralized server. It also starts the software elements in a certain order, respecting important architectural invariants. This protocol supports virtual machine and network failures, and always succeeds in deploying an application when faced with a finite number of failures. Designing such highly parallel management protocols is difficult, therefore formal modeling techniques and verification tools were used for validation purposes. The protocol was implemented in Java and was used to deploy industrial applications.
main-SAC14.pdf (407.18 Ko) Télécharger le fichier
hal-00934042 , version 1 (21-01-2014)
  • HAL Id : hal-00934042 , version 1
Xavier Etchevers, Gwen Salaün, Fabienne Boyer, Thierry Coupaye, Noël de Palma. Reliable Self-Deployment of Cloud Applications. SAC 2014 - 29th ACM Symposium on Applied Computing, Mar 2014, Gyeongju, South Korea. ⟨hal-00934042⟩
969 Consultations
354 Téléchargements
