Combining SLiVER with CADP to Analyze Multi-agent Systems - CONVECS Accéder directement au contenu
We present an automated workflow for the analysis of multi-agent systems described in a simple specification language. The procedure is based on a structural encoding of the input system and the property of interest into an LNT program, and relies on the CADP software toolbox to either verify the given property or simulate the encoded system. Counterexamples to properties under verification, as well as simulation traces, are translated into a syntax similar to that of the input language: therefore, no knowledge of CADP is required. The workflow is implemented as a module of the verification tool SLiVER. We present the input specification language, describe the analysis workflow, and show how to invoke SLiVER to verify or simulate two example systems. Then, we provide details on the LNT encoding and the verification procedure.
coordination2020.pdf (280.55 Ko) Télécharger le fichier
hal-02890401 , version 1 (06-07-2020)
Luca Di Stefano, Frédéric Lang, Wendelin Serwe. Combining SLiVER with CADP to Analyze Multi-agent Systems. COORDINATION 2020 - 22nd IFIP WG 6.1 International Conference on Coordination Models and Languages, Jun 2020, La Valetta, Malta. pp.370-385, ⟨10.1007/978-3-030-50029-0_23⟩. ⟨hal-02890401⟩
138 Consultations
76 Téléchargements
