Components with Symbolic Transition Systems: A Java Implementation of Rendez-Vous - LINA - Langages d'Aspects et de Composants Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Component-based software engineering is becoming an important approach for system development. A crucial issue is to fill the gap between high-level models, needed for design and verification, and implementation. This paper introduces first a component model with explicit protocols based on symbolic transition systems. It then presents a Java implementation for it that relies on a rendezvous mechanism to synchronize events between component protocols. This paper shows how to get a correct implementation of a complex rendezvous in presence of full data types, guarded transitions and, possibly, guarded receipts.
Fichier non déposé
hal-00425384 , version 1 (21-10-2009)
  • HAL Id : hal-00425384 , version 1
Fabricio Fernandes, Jean-Claude Royer, Robin Passama. Components with Symbolic Transition Systems: A Java Implementation of Rendez-Vous. Communicating Process Architecture Conference 2007, Jul 2007, United Kingdom. pp.89-107. ⟨hal-00425384⟩
135 Consultations
0 Téléchargements
