Memory-Augmented Reinforcement Learning for Image-Goal Navigation - Apprentissage de modèles visuels à partir de données massives Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this work, we present a memory-augmented approach for image-goal navigation. Earlier attempts, including RL-based and SLAM-based approaches have either shown poor generalization performance, or are heavily-reliant on pose/depth sensors. Our method is based on an attention-based end-to-end model that leverages an episodic memory to learn to navigate. First, we train a state-embedding network in a selfsupervised fashion, and then use it to embed previously-visited states into the agent’s memory. Our navigation policy takes advantage of this information through an attention mechanism. We validate our approach with extensive evaluations, and show that our model establishes a new state of the art on the challenging Gibson dataset. Furthermore, we achieve this impressive performance from RGB input alone, without access to additional information such as position or depth, in stark contrast to related work.
submitted.pdf (2.93 Mo) Télécharger le fichier
hal-03110875 , version 1 (14-01-2021)
hal-03110875 , version 2 (02-03-2022)
hal-03110875 , version 3 (12-09-2022)
Lina Mezghani, Sainbayar Sukhbaatar, Thibaut Lavril, Oleksandr Maksymets, Dhruv Batra, et al.. Memory-Augmented Reinforcement Learning for Image-Goal Navigation. 2022. ⟨hal-03110875v2⟩
299 Consultations
327 Téléchargements
