LiDARTouch: Monocular metric depth estimation with a few-beam LiDAR - Apprentissage de modèles visuels à partir de données massives Accéder directement au contenu
Article Dans Une Revue Computer Vision and Image Understanding Année : 2023
Vision-based depth estimation is a key feature in autonomous systems, which often relies on a single camera or several independent ones. In such a monocular setup, dense depth is obtained with either additional input from one or several expensive LiDARs, e.g., with 64 beams, or camera-only methods, which suffer from scale-ambiguity and infinite-depth problems. In this paper, we propose a new alternative of densely estimating metric depth by combining a monocular camera with a light-weight LiDAR, e.g., with 4 beams, typical of today's automotive-grade mass-produced laser scanners. Inspired by recent self-supervised methods, we introduce a novel framework, called LiDARTouch, to estimate dense depth maps from monocular images with the help of ``touches'' of LiDAR, i.e., without the need for dense ground-truth depth. In our setup, the minimal LiDAR input contributes on three different levels: as an additional model's input, in a self-supervised LiDAR reconstruction objective function, and to estimate changes of pose (a key component of self-supervised depth estimation architectures). Our LiDARTouch framework achieves new state of the art in self-supervised depth estimation on the KITTI dataset, thus supporting our choices of integrating the very sparse LiDAR signal with other visual features. Moreover, we show that the use of a few-beam LiDAR alleviates scale ambiguity and infinite-depth issues that camera-only methods suffer from. We also demonstrate that methods from the fully-supervised depth-completion literature can be adapted to a self-supervised regime with a minimal LiDAR signal.
LiDARTouch.pdf (5.45 Mo) Télécharger le fichier
hal-03508099 , version 1 (03-01-2022)
hal-03508099 , version 2 (28-11-2022)
Florent Bartoccioni, Éloi Zablocki, Patrick Pérez, Matthieu Cord, Karteek Alahari. LiDARTouch: Monocular metric depth estimation with a few-beam LiDAR. Computer Vision and Image Understanding, 2023, 227, pp.103601. ⟨10.1016/j.cviu.2022.103601⟩. ⟨hal-03508099v2⟩
134 Consultations
69 Téléchargements
