Simple flexible skinning based on manifold modeling - EVASION Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Cédric Gérot
Lin Lu
  • Fonction : Auteur
  • PersonId : 845872
Boris Thibert
In this paper we propose a simple framework to compute flexible skinning weights, which allows the creation from quasi-rigid to soft deformations. We decompose the input mesh into a set of overlapping regions, in a way similar to the constructive manifold approach. Regions are associated to skeleton bones, and overlaps contain vertices influenced by several bones. A smooth transition function is then defined on overlaps, and is used to compute skinning weights. The size of overlaps can be tuned by the user, enabling an easy control of the desired type of deformations.
hetroy_et_al-grapp2009.pdf (578.33 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
inria-00339413 , version 1 (17-11-2008)
inria-00339413 , version 2 (23-05-2016)
  • HAL Id : inria-00339413 , version 1
Franck Hétroy, Cédric Gérot, Lin Lu, Boris Thibert. Simple flexible skinning based on manifold modeling. International Conference on Computer Graphics Theory and Applications (GRAPP), Feb 2009, Lisbon, Portugal. ⟨inria-00339413v1⟩
580 Consultations
584 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
