KinoAI et le carnet audiovisuel : une solution plurielle pour l’étude des répétitions - IMAGINE Accéder directement au contenu
Article Dans Une Revue European Journal of Theatre and Performance Année : 2020
KinoAI and the audiovisual notebook : a plural solution for rehearsal studies
The ever-growing production of video traces of theatrical work, is both an opportunity and a challenge for researchers in performing art studies. In this communication, we report on the work of an interdisciplinary team of computer scientists, performing art researchers and stage and video artists, towards the common goal of transforming raw video recordings of theatre rehearsals into meaningful movie narratives. Our prototype system, KinoAI, combines sophisticated artificial intelligence techniques with a careful dramaturgic analysis of the rehearsals. We present extensive field experiments and propose new research directions.
KinoAI et le carnet audiovisuel : une solution plurielle pour l'étude des répétitions The ever-growing production of video traces of theatrical work, is both an opportunity and a challenge for researchers in performing art studies. In this communication, we report on the work of an interdisciplinary team of computer scientists, performing art researchers and stage and video artists, towards the common goal of transforming raw video recordings of theatre rehearsals into meaningful movie narratives. Our prototype system, KinoAI, combines sophisticated artificial intelligence techniques with a careful dramaturgic analysis of the rehearsals. We present extensive field experiments and propose new research directions.
EASTAP_AUTHORS_COPY.pdf (4.28 Mo) Télécharger le fichier
Format : Figure, Image
hal-02797350 , version 1 (05-06-2020)
  • HAL Id : hal-02797350 , version 1
Rémi Ronfard, Julie Valéro. KinoAI et le carnet audiovisuel : une solution plurielle pour l’étude des répétitions. European Journal of Theatre and Performance, 2020, 2, pp.334-375. ⟨hal-02797350⟩
181 Consultations
242 Téléchargements
