Distorsions des systèmes de reproduction musicale : Protocole de caractérisation perceptive - Thèses du Laboratoire de Mécanique et d'Acoustique Accéder directement au contenu
Thèse Année : 2012
Distortion of music reproduction systems : Protocol for a perceptual characterisation
Pierre-Yohan Michaud
  • Fonction : Auteur
  • PersonId : 938649
This work deals with the perceptual evaluation of the sound reproduction. Our aim is to elaborate a protocol allowing to assess the influence of nonlinearities and distortions of a loudspeaker. Such a protocol requires gathering a large set of loudspeakers together with an appropriate method for its evaluation. This study deals with the perceptual evaluation of dissimilarities between different loudspeakers rather than their absolute quality judgments. Thanks to a multidimensional scaling technique, this approach allows to uncover the criteria used by the listeners to differentiate various distorting loudspeakers. First, we used synthesized signals to generate samples of sounds resulting from controlled distortion. Numerous distorted stimuli have been generated that simulate sounds radiated by a loudspeaker. Then, we propose a method suitable for the evaluation of a large set of stimuli. In order to verify its application to the estimation of dissimilarity, simulations and listening tests have been conducted. Finally, this listening test method has been applied to the created set of distorting loudspeakers in order to verify the use of our protocol and provide some preliminaries results concerning the perception of nonlinear distortion.
Ces travaux concernent l'évaluation perceptive de la reproduction sonore. Le but de notre étude est de proposer un protocole permettant la caractérisation perceptive des non-linéarités et des phénomènes de distorsion modifiant le signal reproduit par un système tel qu'une enceinte acoustique. L'élaboration d'un tel protocole nécessite de rassembler de nombreuses enceintes et d'utiliser une méthode d'évaluation adaptée. Nous ne cherchons pas à évaluer la distorsion en terme de qualité globale mais plutôt à estimer les dissemblances perçues entre différentes enceintes distordues afin de révéler, grâce à une analyse multidimensionnelle MDS, les critères sur lesquelles les auditeurs se basent pour les différencier. Dans un premier temps, nous avons utilisé des signaux de synthèse afin de générer des échantillons dont la distorsion est contrôlable. Nous avons ainsi créé un corpus composé de nombreux échantillons distordus simulant ou se rapprochant du fonctionnement d'une enceinte acoustique avec différents types de non-linéarités. Ensuite nous proposons une méthode adaptée à l'évaluation de la dissemblance sur des corpus étendus que nous avons validée à partir de simulations et de tests d'écoute. Enfin, nous avons appliqué cette méthode d'évaluation sur le corpus d'enceintes que nous avons élaboré afin de tester l'utilisation du protocole proposé et de donner quelques résultats préliminaires concernant les dimensions perceptives liées à la distorsion non linéaire.
PY_MICHAUD_Manuscrit.pdf (1.83 Mo) Télécharger le fichier
tel-00806288 , version 1 (02-04-2013)
tel-00806288 , version 2 (12-12-2013)
  • HAL Id : tel-00806288 , version 2
Pierre-Yohan Michaud. Distorsions des systèmes de reproduction musicale : Protocole de caractérisation perceptive. Acoustique [physics.class-ph]. Aix-Marseille Université, 2012. Français. ⟨NNT : ⟩. ⟨tel-00806288v2⟩
476 Consultations
2294 Téléchargements
