Un modèle de poutre à section mince flexible - Application aux pliages 3D de mètres rubans - Thèses du Laboratoire de Mécanique et d'Acoustique Accéder directement au contenu
Thèse Année : 2013
A rod model with flexible thin-walled cross-section - Application to the folding of tape springs in 3D
Elia Picault
This work was carried out within the framework of a collaboration between the LMA and Thales Alenia Space. We focus on the behaviour of flexible structures and more specifically of tape springs, whose particularity lies in their capacity to coil up or to form localized folds through the flattening of their cross-section. A first thesis led to the development of a new type of tape spring whose uncoiling is controlled thermically on one hand and of a planar rod model with a flexible thin-walled cross-section on the other hand. In this thesis, we offer an extended version of this model dedicated to the simulation of three-dimensional dynamic behavior of tape springs in large displacements and large rotations. This model is derived from shell theory and is based on the introduction of adapted kinematic and sthenic hypotheses. The deformation of the cross-section is characterized by that of its average line which can deform in its own plane by flexion and twisting but not by extension, as well as out of its plane through torsional warping. The large changes of the cross-section shape in its plane can then be described by an Elastica kinematics, whereas a Vlassov kinematics is used to define the warping in the local frame attached to the section. The unidimensionnal model is obtained by integration over the cross-section of the expressions of the shell theory, an energetic approach then allows to express the associated problem which is solved thanks to the finite element modeling software COMSOL.
Ce travail a pour cadre une collaboration entre le LMA et Thales Alenia Space. Nous nous intéressons au comportement des structures flexibles et plus particulièrement des mètres rubans qui ont la particularité de pouvoir, grâce à l'aplatissement de la section, s'enrouler ou développer des pliages localisés. Une première thèse a permis d'une part la mise au point d'un nouveau type de mètre ruban au déroulement maîtrisable thermiquement et d'autre part le développement d'un modèle plan de poutre à section flexible. Dans le travail de thèse présenté ici, nous proposons une version étendue de ce modèle adaptée à la simulation du comportement dynamique tridimensionnel des mètres rubans en grands déplacements et en grandes rotations. Ce modèle est dérivé de la théorie des coques et repose sur l'introduction d'hypothèses cinématiques et sthéniques adaptées. La déformation de la section est caractérisée par celle de sa ligne moyenne qui peut se déformer dans son plan par flexion et torsion mais non par extension, ainsi que hors de son plan par gauchissement de torsion. Les fortes variations de forme de la section dans son plan peuvent alors être décrites par une cinématique de type Elastica, tandis qu'une cinématique de type Vlassov est utilisée pour définir le gauchissement dans le repère local attaché à la section. Le modèle unidimensionnel est obtenu par intégration sur la section des expressions de la théorie des coques, une approche énergétique permet ensuite de formuler le problème associé qui est résolu grâce au logiciel de modélisation par éléments finis COMSOL.
Memoire_EPicault.pdf (16.19 Mo) Télécharger le fichier
tel-00921931 , version 1 (22-12-2013)
  • HAL Id : tel-00921931 , version 1
Elia Picault. Un modèle de poutre à section mince flexible - Application aux pliages 3D de mètres rubans. Mécanique des solides [physics.class-ph]. Aix-Marseille Université, 2013. Français. ⟨NNT : ⟩. ⟨tel-00921931⟩
535 Consultations
3358 Téléchargements
