A new constitutive equation for elastoviscoplastic fluid flows - Laboratoire de Modélisation et de Calcul Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
Pierre Saramito
From a thermodynamic theory, a new model for elastoviscoplastic fluid flow is presented. It extends the Bingham viscoplastic model and the Oldroyd viscoelastic model. Fundamental flows are studied: simple shear flow, uniaxial elongation and large amplitude oscillatory shear (LAOS). The complex moduli (G',G'') are founded to be in qualitative agreement with experimental data for materials that present microscopic network structures and large scale rearrangements.
evp.pdf (254.78 Ko) Télécharger le fichier
hal-00109101 , version 2 (24-10-2006)
hal-00109101 , version 1 (24-10-2006)
hal-00109101 , version 3 (08-02-2007)
hal-00109101 , version 4 (02-04-2007)
  • HAL Id : hal-00109101 , version 3
Pierre Saramito. A new constitutive equation for elastoviscoplastic fluid flows. 2007. ⟨hal-00109101v3⟩
394 Consultations
930 Téléchargements
