Naviguer dans des grands arbres avec ControlTree - Laboratoire de recherche en informatique. Équipe: Informatique Centrée sur l'humain Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This article presents ControlTree, a relevant technique to select a node is a very large node-link representation using a continuous interaction. The node-link representation is dynamic and driven by the cursor location to optimize screen space and to ease the selections. ControlTree uses a snapping mechanism and adapts the OrthoZoom technique to offer an alternative to common "point-and-click" techniques. We also present a preliminary theoretical evaluation showing that ControlTree is a promising technique.
ControlTree_IHM07.pdf (319.61 Ko) Télécharger le fichier
inria-00538506 , version 1 (22-11-2010)
Caroline Appert, Jean-Daniel Fekete. Naviguer dans des grands arbres avec ControlTree. International Conference of the Association Francophone d'Interaction Homme-Machine, 2007, Paris, France. ⟨10.1145/1541436.1541463⟩. ⟨inria-00538506⟩
233 Consultations
190 Téléchargements
