O ESCRITOR INTERMEDIÁRIO: UMA NOVA ABORDAGEM DE UM TIPO DE ESCRITOR - Axe 1 (2017-2021) : "Langage et apprentissage : corpus, cognition, genèse des œuvres " (MSHS Poitiers) Accéder directement au contenu
Article Dans Une Revue Trabalhos em Linguística Aplicada Année : 2017
This research begins with an analysis of the needs of a population Colombian university student, who require the acquisition of academic text writing skills. We propose to analyze the written process by presenting an outline of different theoretical models. Furthermore, we will focus on the notion of the “intermediary writer” as a step in the development of written competence. The intermediate writer, unlike novice writers, can articulate, understand, and perform well-structured tasks at the cognitive level, which reveals its capacity to transform them. These qualities allow us to place this kind of writer in a “mode of understanding knowledge” due to the characteristics that it exhibits prior to the writing process. Thus, he should not be considered as a novice writer, since he has the capacity to go beyond the simple enunciation of knowledge, however, he can not be considered as an “experienced writer”, since his capacity of writing to transform Knowledge. Keywords: written production, beginner writer, intermediate writer, experienced writer.
Cette recherche trouve sa source dans une analyse des besoins d’un public d’étudiants universitaires colombiens qui souhaitent améliorer leurs compétences en rédaction de documents académiques. Nous nous proposons tout d’abord d’analyser le processus de production écrite en présentant un panorama des différentes propositions théoriques. Dans la suite de cette analyse, nous nous concentrerons sur la notion du « scripteur intermédiaire » comme une étape dans le processus du développement de la compétence écrite. Il s’agit alors d’un scripteur qui, contrairement aux scripteurs novices, il peut articuler, comprendre et réaliser des tâches bien structurées, au niveau de la pensée, ce qui révèle sa capacité à les transformer. Ces qualités permettent de les situer dans « le mode de compréhension des connaissances », en raison des caractéristiques présentées face au processus d›écriture. Dans ce sens, il ne peut pas être considéré comme un scripteur novice, car il est au delà de la simple énonciation de la connaissance, mais comme un scripteur expert non plus, car son travail d'écriture ne démontre pas encore sa capacité pour transformer ces connaissances.
Esta pesquisa tem como ponto de partida uma análise das necessidades de um público de estudantes universitários colombianos que desejam melhorar suas competências na escrita de textos acadêmicos. Propomos primeiramente analisar o processo de produção escrita apresentando um panorama de diferentes propostas teóricas. Após a análise, nos concentraremos na noção do “escritor intermediário”, como uma etapa no processo do desenvolvimento da competência escrita. Trata-se então de um escritor que, contrariamente aos escritores novatos, pode articular, compreender e realizar tarefas bem estruturadas em nível de pensamento, o que revela a capacidade de transformálas. Tais qualidades permitem situar o escritor no “modo de compreensão de conhecimento” devido às características que apresenta diante do processo de escrita. Nesse sentido, ele não deve ser considerado um escritor novato, pois tem a capacidade de ir além da simples enunciação de conhecimento, no entanto, não pode ser considerado um “escritor experiente”, já que o seu trabalho de escrita não demonstra ainda a sua capacidade de transformação daqueles conhecimentos. Palavras-chave: produção escrita, escritor novato, escritor intermediário, escritor experiente.
Valetopoulos O escritor 2017 (2).pdf (1.56 Mo) Télécharger le fichier
hal-02063942 , version 1 (24-01-2020)
Cynthia Pires Amaral, Elizabeth Villarreal, Freiderikos Valetopoulos. O ESCRITOR INTERMEDIÁRIO: UMA NOVA ABORDAGEM DE UM TIPO DE ESCRITOR. Trabalhos em Linguística Aplicada, 2017, 56 (2), pp.729-751. ⟨10.1590/010318138648313300201⟩. ⟨hal-02063942⟩
92 Consultations
43 Téléchargements
