Allumage, combustion et explosion des poudres d'aluminium, de titane et de leurs alliages - Modelisation Systemes Langages Accéder directement au contenu
Thèse Année : 2019
Ignition combustion and explosion of aluminum titanium and their alloys powders
In recent years, the layer-by-layer manufacturing process seems to be used increasingly amongst the aeronautics, space or defense industries. These Additive Layer Manufacturing processes use metal powders from metallurgical alloys commonly used in the mechanical industry. The EXPAALT project was developed on the problematic of explosion risk around aluminum, titanium and their alloys powders. This thesis is part of this project and aims to contribute on the one hand to the determination of the safety parameters, and on the other hand to the comprehension of combustion mechanisms of these powders. For such, eleven metal powders were selected including four pure powders and seven alloys. Their combustion characteristics were studied in a 20 liter spherical bomb and in a Hartmann tube. In support of these devices, optical diagnostics, in addition to the pressure sensor of 20 liter spherical bomb, such as a two-color IR pyrometer and a UV-Visible spectrometer were used. The combustion mechanisms were interpreted by combining a thermodynamic equilibrium approach with the combustion products characterization. The results obtained in those different experimental configurations showed that pure powders are more sensitive and more severe to explosion than their alloys. In the combustion products analyzes, it is noted the presence of crystallized and amorphous phases witch showed the complexity of the mechanisms formation of combustion products. In all cases, it appears that oxygen and nitrogen are two reactants during combustion, as evidenced by the analysis of the products. The proportion between oxide and nitride is directly controlled by dust concentration. These results provided new information about the combustion of pure powders and their alloys and showed that we need to evolve combustion models.
Depuis ces dernières années, les procédés de fabrication par addition de matière commencent à faire leur apparition dans les entreprises occupant des secteurs à forte valeur ajoutée comme l’aéronautique, le spatial ou le secteur de l’armement. Ces procédés d’addition de matière mettent en oeuvre des poudres métalliques issues des alliages métallurgiques utilisés couramment dans l’industrie mécanique. Le projet EXPAALT a été développé sur la problématique du risque d’explosion autour des poudres d’aluminium, de titane et de leurs alliages et cette thèse s’inscrit dans ce contexte. Son objectif est de contribuer d’une part à la détermination des paramètres de sécurité de ces poudres, et d’autre part à la compréhension des mécanismes de combustion de celles-ci. Pour ce faire, onze poudres métalliques ont été sélectionnées dont quatre poudres pures et sept alliages. Leurs caractéristiques de combustion ont été étudiées dans une bombe sphérique de 20 litres et dans un tube d’Hartmann. A l’appui de ces dispositifs, des diagnostics optiques, en plus du capteur de pression de la sphère, comme un pyromètre IR à deux couleurs et un spectromètre UV-visible ont été utilisés. Les mécanismes de combustion ont été interprétés en combinant une approche thermodynamique à l’équilibre avec une caractérisation fine des produits de combustion. Les résultats obtenus ont montré que les poudres pures sont plus sensibles et plus sévères à l’explosion que leurs alliages. Dans les analyses des produits de combustion, il est noté la présence de phases cristallisées et de phases amorphes, permettant de mettre en évidence la complexité des mécanismes de formation des produits de combustion. Dans tous les cas de figure, il apparait que l’oxygène et l’azote sont deux réactifs lors de la combustion comme en témoigne l’analyse des produits. La proportion entre oxyde et nitrure est directement contrôlée par la richesse. Ces résultats fournissent des informations nouvelles sur la combustion des poudres pures étudiées et de leurs alliages, montrant la nécessité de faire évoluer les modèles de combustion.
myriam-millogo_4101.pdf (13.4 Mo) Télécharger le fichier
tel-02985934 , version 1 (02-11-2020)
  • HAL Id : tel-02985934 , version 1
Myriam Millogo. Allumage, combustion et explosion des poudres d'aluminium, de titane et de leurs alliages. Autre. Université d'Orléans, 2019. Français. ⟨NNT : 2019ORLE2006⟩. ⟨tel-02985934⟩
215 Consultations
1114 Téléchargements
